One Big thing to remember is that all Deductions lower the bottom line on your return, sounds good huh??
Maybe Not a good thing unless you own your own business or are an LLC or such, and even worse if you work for someone else and have a small business.
The tax codes Invite you to start a business, , build inventory, buy equipment etc. and Allows you to Write lots of it off ( depreciate it over a set time). Still sounds good huh?
Great if you are a Salaried employee for your LLC, get your check and take your standard and itemized deductions you will probably be OK and when you get hurt on the job (disabled) you will get a good SSD check, because you will most likely still have a good sized bottom line.
Now work for someone while getting your own business up and running.
( Remember you are encouraged to do this by our lovely government)
Use the Write Offs from your business to Reduce your total tax liability.
(The Gov. encourages this,remember, "Small business is the Backbone of America")............. Get hurt and you will get Screwed in the long run
By doing what is Encouraged you take the Deductions ( you now have a Small Bottom line) and after you get Disabled ( and all your Private Disability Insurance is gone) you will be stuck with a Very Small Social Security Disability Check.
This happens due to your Lowered Bottom line as SSD payments are based on a 10 year period ( the highest Bottom line of those 10 years) and because you took the Deductions to get your business off the ground you will have a Small bottom line, and that is what your SSD will be based on.
So watch how you use the Deductions that are offered, the Government
will screw you Big time if you get hurt at the Wrong time.
Found out the hard way about 20 years ago after getting my neck broken for the 3rd time. My SSD (adjusted for inflation) is now a wopping $653.00 a month !!!!!!!!!!( not much considering if I had not taken the Deductions I would be getting 3 times that), and at age 60 that ain't much to help with the Golden years.
This is when I made a six figure income and my adjusted was in the 35K range.
So, watch how you use those Deductions, and buy as much Disability Insurance as you Cannot make a good new start without it. BTW, I did, and it was/ is still a bitch. My .02 cents
