Throttle position sensor
p33tef
Hi guys
My truck is running real rough idle speed varies and when driving power loss occurs. Error code shows throttle position sensor circuit insufficient activity.
Any help please
TPS is covered under warranty. Mine went bad fairly early.. Like 9,000 miles on the odo. But I had it replaced and it's been fine for years.
Simple fix if it's not under warranty - two screws, one connector.
Just have to make sure the throttle shaft tang is engaged in the sensor properly so when you operate the throttle, the sensor components can move properly.
