BLACK10
I wasted $1,700 bucks on the BF GOODRICH KDW2's :thumpdown: tires arent worth a crap any one tried any other brands if so please let me know
BLACK10 said:I thought they would hook up better than the pirelli's but I was wrong...also they suck in wet driving conditions.
JRSVIPR said:I have been running the BFG's for about 5000 miles with no problems. Not much wet weather here though. Also i do not run at the track. But as far as hooking up, I'v had good luck with them. I'm pretty much stock to so? I do push it pretty hard though.
J.R.
Did you put 500 miles on them yet? I think BF uses more preservatives than the others and you can't simply "burn" it off.:burnout:BLACK10 said:I thought they would hook up better than the pirelli's but I was wrong...also they suck in wet driving conditions.
brandon93 said:the kdw's are a great tire, & they are designed for the wet (k=keyed d=dry w=wet) the 2nd & 4th tread have a different compound, specificly for the wet weather. get a little heat in them & they work great, if you r looking for drag race traction you might want to go with a drag radial:burnout:
K-80-123 said:How about these????...they make a 22-inch
FSTJACK said:
I'd rather have a sister in a whorehouse than a General or Firestone on my vehicle.
dilly03 said:I have these on my truck. My truck shook between 75-80 with the original tires. After trying 8 other tires (12 total) from Pirelli, my service guy got fed up and put these guys on they and now there is no vibration whatsoever. Didn't pay a dime for them 'cus Pirelli can't make a round tire, but it appears they are going for $191 a piece on tirerack. Both the dry and wet grip seems to be slightly better than the Prielli's.
http://www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=Grabber+UHP
Rice Eater said:man i upgraded to the KDW2's on my old magnum. IMO they hooked great and cornered even better....but then again I was used to the crappy ass conti's that came on it stock. How much narrower are the KDW2's than the scorps?
