It should tell you in the owner's manual. But if you open the tonneau flip the latch down on each side like it is closed the metal tabs should come down then just remove the remove the 2 bolts near the cab then go back to the rear and undo the quick releases on the hydrualic arms and lock them up in the stow away clips then sit it down on the metal tabs. At this point all you will need is 2 people one on each side to lift off. Good Luck.
