Cbailey8971
I have a 04 rc can't find tow rating info.
What can you tow as far as weight? What it's everyone towed ?
So what is wrong with the silver truck?
dropped a valve seat on the right side cylinder head, damage to head, 2 pistons and the block
How many miles on the engine? What would cause something like that?
92k, the most common cause is overheating. However it doesn't appear to be the case here.
Heard if you are going to tow with a RC..don't use 6th gear.
So what are the plans for this one.
OK, Now your just showing off...
What happened to the silver one? dropped valve while towing....:drool:
I slapped on a hitch to my RC about 10yrs ago. Most I tow is trailer with a couple motorcycles/gear (1500lbs). Biggest reason for no towing with RC is due to clutch. Keep the slipping to min and truck does fine. If your RC is dropped like mine your tongue weight is greatly reduced...not much rear travel.
