Tremec Output Yoke
Chuck B
Phoenix, AZ
I'm now just shy of 100K and rear trans seal is beginning to weep a bit again. Last time I replaced the seal but it continued to weep. Pulled the yoke and sanded with wet/dry and its been fine till just recently. Looking to see if there are aftermarket alternatives as a yoke replacement. THIA!
oem I can do for $119.99 prob $10 shipping, but just got off the phone with DTS and we went thru all they had and come up empty, got close on a 30 spine yoke ,but no potatoes
Thanks for checking.... I know of a couple for the Viper but not for Ram application. I have no issue with OEM but wanted to see of other options are out there.
Try these guys:) Don't know if this will work, but they can probably fix you up
http://www.dennysdriveshaft.com/p29...__a833_manual_and_t_56_viper_with_2930_s.html
1350 Series 727 auto & A833 manual and T-56 VIPER with 29/30 spline output
Part #: SY1350-727 $79.95 $62.95 each
THIS ITEM IS ON SALE!
Click for Larger Photo Status: In Stock, Usually Shipped Within 2 Days
$79.95 $62.95 each
Add to Shopping Cart
Click Here to Buy Online
1350 Series 727 auto & A833 manual and T-56 VIPER Spicer Transmission Slip Yoke with 29/30 spline output.
Length to center of u-joint... Dimension #1 = 6 5/8 inches
Barrel Diameter... Dimension #2 = 1 11/16 inches
Barrel Length... Dimension #3 = inches
U-joint cap diameter... Dimension #4 = 1 3/16 inches
U-joint width... Dimension #5 = 3 5/8 inches
Series... 1350
Spline count... 30
Worht a try , they may have what is needed :dontknow:
