Hey guys, I got my 2005 SRT10 Quad a couple months ago after going temporarily insane and buying it from an out of state dealer without even driving it. It had a ton of mods done already - paxton, nitrous, xmetal TB, Bassani headers, MBRP exhaust, lowered, guages, grill, mirrors, rotors, trans and TC.
It arrived with the CEL on and a slight missfire. After a failed leakdown test and head removal, a broken piston and ring were found along with a number of other worn parts. It sat at a certain shop for 2 months before I got a super high repair estimate after which I pulled it from that shop.
I am having the engine rebuilt 10 over, forged pistons and rods of course, port and polish heads, match port intake, roller rockers, etc.
Now with the questions I hope you guys can help me with:
1) Would a cam designed to work with the SC be advised and worth the cost?
2) Is there anyone who has or makes a dedicated belt drive system for the paxton?
3) What is a safe amount of boost with pump gas and are bigger injectors advised? If so, what size?
4) This truck supposedly has the "$5000" trans and aftermarket converter. How can I tell which company built it and what converter it has? Can't seem to find any tags or numbers on either.
5) Does the 'built" trans use the ATF+4 fluid or something different?
6) Anyone know where to get a good shop manual for this truck as I have to put the engine back in having not been the one to remove it. (wires and plugs everywhere)
Thank you for any help you can provide!!
