Heart Attack
where is it?
just swaped out the crankshaft sensor, still a no go, im gonna swap out the camshaft sensor in the morning and see if that fixes it.
Heart Attack, in your video it looks like you needed a jump to get it started and your volt gauge looks like your voltage is still low. Start with basics and get a known good battery in to start and run the truck. Low voltage can cause havoc on proper sensor signals AND low voltage can make a fuel pump not put out proper supply pressure especially if you got an aftermarket fuel pump with your Paxton install. Give Er a try I've seen some weird stuff from batteries or loose terminals.
just tried again with fresh batteries. still a no go and still acts the same
