Scrambler1
Yeah Justin we'll see what it ends up doing. I'll be leaving off a transbrake but may add a two step or a small shot to get them spooling off the line. But yes PT88 T4's.
Scrambler1 said:Yeah Justin we'll see what it ends up doing. I'll be leaving off a transbrake but may add a two step or a small shot to get them spooling off the line. But yes PT88 T4's.
JMB Justin said:No offense taken at all, its merely a discussion and I put in my .02. I can overlap doms sheets but they wont tell you much since it has to be in MPH (lost tach signal, so torque reading is all screwed up) and he did a gear change from 4.11 to 3.73 so when read in MPH, they dont line up.
No matter what you will trade low end for top end on a turbo setup with no other power adders, its just a matter of how much you want to trade. Doms original motor without heads/cam picked up over 600whp with the turbo kit, no internal changes made at all, full boost in the 2800 rpm area, his new turbo picked up 850-900whp over his motor NA, but full spool at 3400rpm approx. on the street (full spool depends on the amount of boost obviously). Looking at his new sheet, even on pump gas it picks up 500+whp from 95 to 115mph, and on race gas it picks up over 850whp from 95 to 125MPH (pulls to 150 in 4th)
I do have to disagree with Joe in the statement that twin 88's can spool at 2500rpm on a viper motor (or even 76's for that matter), Tonys was spooling low to mid 3000's with 67's and im guessing your using Precision PT88 T4's which are also journal bearing. Even ball bearing wont make that much difference on this application, at best 3-500 rpm. I would guess on the dyno, 4K+ RPM spool (to 15psi), on the street, probably mid to high 3000's (heavy QC will certainly help). I really cant see how Doms single T6 88 (with the smallest exhaust side) would spool after your twin t4 88's, but ive been wrong before. Typically in a viper twin PT88's is a 4K+ spool.
Justin
DevilDawg3097 said:I talked to him today, he is checking, and he said to get rid of that new style, youll have nothing but problems, also your 35 is close to the flow but with the hx 40 it can easily be upgraded and run the 50 inerts there is 1.5mm differance in the 50's housing that bolts to the manifold. But you stumped him too and now you have him curious becuase he said in 30yrs that is the first time anyone has ever asked him that:marchmellow: So as soon as I hear from him I will let you know.
will do been busy as mother but I give him a buzz in the am and thankspokeytemplar said:Ask your man if the VGT version only has problems in diesels or is it any engine? Looking forward to seeing his response.:rock: and your build looks great!
Smokey said:back pressure is called "drive pressure" gotta use the right lingo
i'll sell you a slightly used hx35
pokeytemplar said:How much HP does the drive pressure cost then? If I have read correctly Drive pressure is normally 2-1.75:1 and perfection would be 1:1. So if you are running 18psi of boost there would be anywhere from 36-18psi of drive pressure. That pressure would reduce the efficiency of the engine. That would be the "cost" of driving the turbo. Now we can accurately calculate the HP required to drive the turbos. Thanks Smokey!:rock:
Smokey said:being diesel, i know turbos better then blowers, but it depends on the drive pressure ur willing to live with, i doubt thay u'll see a drive pressure that high, if so....u messed up and are gunna break shit... ive seen drive pressure that high on spray and thats it, because its more then the waste gate can handle. besides that what waste gates help eliminate, they bleed excess drive pressure out of the turbo thus lowering the drive pressure.
im running a stock turbo in my truck at 38lbs boost, drive is 45 (1.1:1)
IMO turbo>blower:burnout:
outta curiousity, why are you trying to figure this out? no matter what power adder you do, your going to lose power off something good thread tho
dnz28 said:Turbochargers have to be picked out for the application, It Can be as efficent as a blower or better, Its a real trade off if you want less drive the turbo will then be more efficent but it will take forever to build boost. but if you want to take a hit in alittle hp but gain power where its needed and make the powerband wider you want drive pressure. its all in what your after, thats why turbos are so loved. Also a turbocharged engine will respond to engine load better than a charger. Also with cutting drive pressure your peak boost will be limited.
dnz28 said:i like turbos and they just out perform chargers
WOT said:Pokey, on some high output engines, there have been examples of drive pressure ratios less than 1. That means that for example if you are making 30psi boost, it is taking less than 30 psi to drive the turbine. In that case, you actually are gaining power (besides the fact that the boost gains you power) due to the fact that the 30 psi on the intake side pushes down on the piston during the intake stroke and makes up for the 30 psi pressure on the exhaust side. With optimized cam timing, you have a 0 hp cost for the turbo. This was supposedly done with a very large turbo and A/R, for a stationary engine.
Of course this wouldn't work during transient conditions (coming off idle, shifting gears, etc). But, it just shows that you can have a turbo with no HP cost at certain states.
