wesleymltn said:are u runing the stock fuel system
I've got an additional in tank fuel pump, and the larger injectors that come with the Roe kit.
alexspop said:Those 2 long weekends every month can get expensive.
wesleymltn said:have any of u guys seen a kenny bell or prochrager on on these trucks one of my friends keeps tellin me that prochrager makes a kit for the truck but i cant find it
LoveThisTruck said:2 long weekends? I'm at work now
alexspop said:We used to get a 3 and 4 day between rotations.
how much boost could the procharger turnFSTJACK said:ProCharger does not make a "kit" for the SRT-10 truck.
As stated Justin does make the necessary "kit" to install a ProCharger on the truck.
My red truck was the first to have a F2 ProCharger fitted by justin to make the prototype kit.
The red truck was originally fitted with the Paxton supercharger and on the built motor we could only make 3.5 lbs of boost. That was changing pully sizes and every trick in the book to get more boost.
You can contact Justin for more information.
wesleymltn said:how much boost could the procharger turn
so how much power were u making with the procharger and at what psi were u makin itFSTJACK said:The F2 ProCharger I have could make 38psi acording to ProCharger and support 1600HP.
It is on the small side for the motor I have.
wesleymltn said:so how much power were u making with the procharger and at what psi were u makin it
wesleymltn said:how would nitrous react with the roe i was thinkin it should make it run alot stronger because of the nitrous helpin it cool
