Apr 24, 2014 #1 5 58lymouth Full Access Member Joined Feb 20, 2014 Messages 135 Reaction score 0 Is there a place on the engine where there is a decent size vacuum outlet on a srt10 ??? Can't seem to find one
Apr 24, 2014 #2 ARRESTmeRed04 Active Member Supporting Member Joined Nov 5, 2007 Messages 5,882 Reaction score 2 Location central texas Should be a 1/2 inch or so port on the drivers side near the rear. Usually used for the brake booster
Apr 24, 2014 #3 BAD SNAKE Full Access Member Joined May 21, 2011 Messages 994 Reaction score 0 Location DC/MD/VA Area there is also one right behind the throttle body on the bottom of the intake manifold and if you run a JTSVP TB there is one on the bottom of his TB
Apr 26, 2014 #4 5 58lymouth Full Access Member Joined Feb 20, 2014 Messages 135 Reaction score 0 Hey, thanks guys. I'm new at this and really appreciate it
Apr 26, 2014 #5 5 58lymouth Full Access Member Joined Feb 20, 2014 Messages 135 Reaction score 0 I assume that front vacuum outlet feed both valve cover inlets to suck the fumes out right?
