Venom Series shifters
Status
Not open for further replies.
1. oldcolt
1. moparman95
1. ramchargerguy
1. 04viperram
1. sim333
1. moparman95
1. serpent
1. thumperama
1. bluebird
1. TNVIPER
1. Oncebitten
means that you will be able to adjust the spring tension on the movement.
in other words all the way adjsuted out will be better then oem, comparable to a B@M shifter to sorts, turn the adjuster in a 1/4 turn or so and it puts more pressure on the spring, thus "stiffening" up the shift between gears, so basically the shift from gear to gear will be a little firmer,
this gives guys that are quicker on the shift a more positive shift.
put me down for 1.also need more led bulbs got problem with ones for the TBSS do i need a resistor or something also the HID harness for my trk you got any instrutions or a pic for all them wires?also need a VCA truck and i need tlk to you about elec fan kit.and porting aTB call me when u got time thanks
will give you a shout tomorrow buddy:call:
just a note, all the hardware is going to be stainless steel in the shifters,
also everything is going to be all billet aluminum and beefed up in certain areas
should be about another three weeks I hope fellas
prototype test
Update on the Venom Shifter
''This thing is badass,I have been driving around town all mourning.Rowing through the gears with this shifter is fantastic.There is no slop,It,s solid,Hell i even tried to miss third.Very short throw,Even when looking for reverse you barely move the stick over and up,your in.Kinda like sex if i remember right.But anywho,I played with the tension spring adjustment,And if you crank them down it's tighter than..........Well you know.I have them backed out right now for normal street driving with occasional woop ass mode.I'm telling you this shifter is rock solid,With dependable shifts,And positive engagement.I also have the stick adjusted so that there is one more adjustment down. ''
Status
