Viper Truck Registry
Started adding ACR (Competition Group) details to the Registry. This will take some time.
Viper Truck Registry-1999 Viper
I decided not to use the "ACR" because in the early years, of the ACR, it wasn't really clear in the data that I have
The Viper Registry: Viper Registry and the Viper Truck Registry: Viper Truck Registry are coming along great. Slowly getting things added and I may be way behind schedule, however, I'm making pretty decent progress.
Thanks to Andy, build dates are coming along well, going to be a hell of a list folks
Jeff
ViperJeff
Can you please add me to the registry.
Thanks:D
Paul (mcdoogle1975)
Added....
I'll post the link when I have your page ready
Dodge RAM SRT-10
Details
mcdoogle1975
VTR-2193
Build Number: #2749 of 3057
Build Date: 6/23/2004
2004 DODGE RAM 1500 REG. CAB PICKUP
PX8A Black Clear Coat
Mileage:
VIN: VTR Verified
Frankfort NY, US
Notes
MODS
NOVI 2000 SUPERCHARGER
VIPER LOW COMPRESSION C-P PISTON & RING KIT
MANLEY PRO BEAM RODS
FULL GASKET & SEAL SET W/COMETIC HEAD GASKET
VIPER BEARING SET
VIPER VALVE KEEPER SET
VIPER RACE- FLOW VALVES PRO FLOW
VALVE SPRING & TITANIUM RETAINER SET
BILLETT MAIN CAPS
PORT & POLISH CYLINDER HEADS
MULTI ANGLE VALVE JOB
BALANCE ROTATING ASSEMBLY
REGRIND CRANKSHAFT ROD PINS TO SBC BEARING SIZE.
POLISH MAINS & REWORK OIL HOLES
CYLINDER HONE BLOCK
HARLEN SHARP ROLLER ROCKERS VIPER V10 1.7 RATIO
BILLETT ALUMINUM SUPERCHARGER PULLEY
CUSTOM COMP CAM
CLEVITE BEARINGS
180 DEGREE THERMOSTAT
1200 DEGREE SPARK PLUG WIRES-BILLETT WIRE SEPARATORS
JTSVP VIPER COIL PAK
BILLET VALVE COVER SPACERS
JTSVP SS OIL LINES
JTVSP SS POWER STEERING LINES
CUSTOM AIR/WATER INTERCOOLER SYSTEM
MPI TUNER
INTERCOOLER SS HOSE KIT
X-METAL SINGLE BLADE THROTTLE BODY
X-METAL BILLET FUEL RAILS
WELDON FUEL REGULATOR
JMB DUAL IN TANK FUEL PUMPS
SS FUEL LINES
X-METAL HEAT EXCHANGER
DC PERFORMANCE AIR INDUCTION BOX
JMB POWDER COATED VALVE COVERS
JMB POWDER COATED HARD RADIATOR PIPES
JMB POWDER COATED OIL CATCH CAN
JMB POWDER COATED COOLANT RESERVOIR
JMB POWDER COATED WW RESERVOIR
JMB POWDER COATED HURST LINE LOCK
BASSANI SHORTY CERAMIC COATED HEADERS
X-METAL 3 INCH MIDPIPES NO CATS
B&B SS CAT BACK EXHAUST 3 INCH
Equipment Listing
VIN VTR Verified
Vehicle Description 2004 DODGE RAM 1500 REG. CAB PICKUP
Monotone Paint
136 Amp Alternator
Front Height Adjust Shoulder Belts
Passenger Air Bag On/Off Switch
Next Gen Multistage Front Air Bags**
Floor Covering Carpet
Passenger Assist Handle
Behind the Seat Storage / Bin
Tinted Glass Windows
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
Remote Keyless Entry
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Cluster w/Tach
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Glove Box Lamp
Halogen Headlamps
Cargo Lamp
STANDARD EQUIPMENT
Front License Plate Bracket
Dodge Badge
Removable Tailgate w/Caliper Latches
26 Gallon Fuel Tank
Speed Control
Black Clear Coat
Tilt Steering Column
Tire Carrier Winch
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6750#
U.S. Dealer Retail
Zone 32-New York
Two Wheel Drive (2WD)/(4X2)
6 FT. Cargo Box
Regular Cab
1500 Series
DR-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
New Jersey Ship to State Code
New Jersey Sold to State Code
Leather Seats w/Perforated Suede
Dark Slate Gray
Light Group
SRT Group
OPTIONAL EQUIPMENT
Security Group
8.3L Eng(EWC)/6Spd M/T (DEC)
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Perf Brakes
40/20/40 Split Bench Seat
Supplemental Side Air Bags
Supp Side Curtain Front Air Bags
Front Floor Mats
Front Center Seat Cushion Storage
O/Head Console w/Trip Computer/UGDO
All Manual Transmissions
6-Speed Manual TREMEC Transmission
4.10 Rear Axle Ratio
200MM Rear Axle
Anti-Spin Differential Rear Axle
8.3L V10 SFI Engine
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
All Vehicles W/Power Mirrors
Satin Silver Lock Knobs
Sentry Key Theft Deterrent System
Air Cond'ing w/Dual Zone Temp Cntrl
Instr. Panel Sport Bezel
160 MPH Primary Speedometer
Black Clear Coat - Molding - Sill
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Fog Lamps
Security Alarm
Body Color Grille
Hood Power Bulge
Body Color Front Fascia
Body Color Rear Fascia
Ram SRT10 Badge
SRT10 Badge
Viper Powered Badge
Rear Bodycolor Spoiler
50 State Emissions
Federal HDV1, Cal. MDV 1 ULEV II
Bright Exhaust Tip
Dual Rear Exhaust w/Bright Tips
Maximum Duty Engine Cooling
Black Clear Coat
All Radio Equipped Vehicles
Uconnect 8.4N CD/DVD/MP3/WMA/MW/FM
8 Infinity Speakers w/Subwoofer
Fixed Long Mast Antenna
508 Watt Amplifier
Steering Wheel Mounted Audio Ctrls
Performance Steering
Leather Wrapped Steering Wheel
Front Perf Tuned Shock Absorbers
Rear Perf Tuned Shock Absorbers
Rear Perf Tuned Stabilizer Bar
Front Perf Tuned Stabilizer Bar
Compact Spare Tire
P285/40R22 BSW All Season Tires
Pirelli Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
22X10.0 Aluminum Polished Wheels
Power Adjustable Pedals
Bright Pedals
Hurst Shifter
Under Rail Box Bedliner
2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM: DR TRACKING: 30910M09AA MY:2004
FAM: DR TRACKING: 204SRT01AS MY:2004
FAM: DR TRACKING: 30910M09AC MY:2004
Customer Preferred Package 2TS
Customer Preferred Package 29S
Pre-Spec Vehicle Order Tracking
ProMaster City Equipment Tracking
Waterbase Paint
Paint Order Code
Also, as a note to those that are considering Dash Plaques. I will be moving in the next few months and I will no longer be able to just pick up the plaques from my engraver. he will need to ship them to me. He has told me that they send everything out the same way and that cost to me is 6.99. Which means, for single dash plaque orders, the price will go up that much. That leaves me looking at a price of 25+ bucks which is just to high. So about the only way these might continue is by bulk orders or not at all. I will keep you updated.
Also, as I'm no longer part of the staff, I may not be able to sell these openly here
caveman, please advise
Might make what I need to do a hell of a lot easier
Jeff
Jeff
You provide a service that we are all grateful for. Please continue doing what you are doing.
Thank you sir,
I just need to do something about the cost side of this. I'm thinking the only way to do this is group buys (bulk order), I can get them cheaper and even with the shipping, the cost will go down. I just can't see making someone wait 6 months while I wait for enough to have an order processed.
After sleeping on it, not sure if the plaques will survive the move
jeff
Finally getting around to sending this in...
Thanks,
David
Thanks,
David
Thanks David,
Dodge RAM SRT-10
Details
Conan
VTR-2636
Build Number: #1422 of 3057
Build Date: 3/24/2004 11:00:00 PM
PR4A Flame Red Clear Coat
Mileage:
VIN: VTR Verified
Brandon FL, US
Equipment Listing
VIN VTR Verified
Monotone Paint
136 Amp Alternator
Route 81 - UP, Centreville, IL
Cigar Lighter
Power Locks
Glove Box Lamp
STANDARD EQUIPMENT
Halogen Headlamps
Cargo Lamp
Dodge Badge
26 Gallon Fuel Tank
Speed Control
Tire Carrier Winch
Pickup Box
GVW Rating - 6750#
U.S. Dealer Retail
Zone 42-Detroit
6 FT. Cargo Box
Regular Cab
1500 Series
DR-Vehicle Family
Kentucky Ship to State Code
Kentucky Sold to State Code
Dark Slate Gray
OPTIONAL EQUIPMENT
Light Group
SRT Group
Security Group
Front Floor Mats
200MM Rear Axle
8.3L V10 SFI Engine
Rear Sliding Window
Flame Red Clear-Coat - Molding - Si
Ash Tray Lamp
Underhood Lamp
Fog Lamps
Security Alarm
Body Color Grille
Hood Power Bulge
Ram SRT10 Badge
SRT10 Badge
Viper Powered Badge
50 State Emissions
Bright Exhaust Tip
AM/FM CD 6-Disc Radio
508 Watt Amplifier
Compact Spare Tire
Pirelli Brand Tires
All Aluminum Wheels
Center Hub
Bright Pedals
Hurst Shifter
Manuf Statement of Origin
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Distribution Services Tracking
Waterbase Paint
Paint Order Code
Have a Great Day
OK, here's the problem with the dash plaques. Currently (if still offered) they are $18.50. I would order them and go pick them up so there is no shipping cost. That shipping cost is $6.99. So a single order would be 25.49. I think everyone would agree that's a bit much for a dash plaque. So the only way to make this affordable would be a group buy (30 or more), which would also reduce the price of the plaque because I get a volume discount. With that discount the price would go to $14.50. Hell, I 'm not sure we could put a list of 30 together in a short time frame. So wait times could be so long that when we think we have the count, half will have dropped off because they no longer want or need one. Not sure what to do or to do anything at all.
Jeff they are every bit worth the price. If someone were to go about it on their own they'd spend more. I'd try a group buy of 20 and see where that goes but otherwise your price is fair and quality is there :)
Thanks Scott. Nothing will happen til after the move. Hoping to close around the 1st of May.
And in all honesty, you can get one done yourself for less than 25 bucks or even 18 bucks for that matter. You would just have to do all the leg work and put it in a format the sign shop can work with. The first ones that Jim helped me with I think were only 7 bucks each, however they were vinyl. Wanted something that looked more in place. Steve did some really cool ones that were multilayered plastic, think they were 10. BigDodgeInAlaska did them for about 25 bucks from what I remember for the small plaque and the under hood one (much bigger) I can't remember.
Value, well, back then we paid 50-60k for our trucks and so 25 bucks was nothing. Now with the truck being 18k, a 25 dollar plaque is two cases of keystone and well, the keystone is a better value
Nah, some of us don't drink and if we did it damn sure wouldn't be Keystone, lmfao. For a metal plaque that's engraved it's worth it today as well. Kinda needs more marketing I think. Kinda like me needing a website, lol.
I used to market it, got to many irritating comments from the peanut gallery. Not like I was making a living on them, so it wasn't worth the trouble.
Web sites, I did that once for a vendor.... lost my shirt
The best thing to do is go to godaddy.com, get a domain, use the online tools and wa-la. No special training or talents needed (for most people). I've had to babysit a few and talk them through things, but hey, it was just time. Uploading pictures is pretty easy and you just have to remember to size them correctly for fast loading.
Most importantly, you have to decide if that web site is worth the trouble and will it bring you additional business. How much time you will spend in it vs getting to do other things you want to do.
Personally, I would forgo the website and use the VTCoA Gallery. You can add pictures with descriptions. make your gallery a public gallery. Add prices if you want and update the price when required.... Create a link in your signature and maybe create a new thread in your forum, make it a sticky so it's always at the top.
Cost..... $0.00
Effort.... Minimal
Cost..... $0.00
Effort.... Minimal
Truth and appreciate the info. Shared the plaque info on FB to see interest.
I will happily pay the $25.50 to get one. Nothing like making it just that more unique, and "certified" compared to the wanna-be trucks here. No lie, four Hemi SRT-10 look a likes in my area. I am one of 3 true SRT-10s in my area. Easy to spot if you know the SRT-10s exterior.
