Streetgliderx
- Joined
- Oct 8, 2008
- Messages
- 520
- Reaction score
- 1
Going stick in an auto. Auto shifts like new has only 33k miles on it. Willing to trade if someone wants to go auto?
I have a bunch of miscellaneous pieces for the swap. Steering column shroud, shifter boots, shifter base, pedals, etc.
Hi, i have pedalbox,shifter column (2005), Hurst shifter
Just let me know, if interested.
Here is the list I put together with the help of E and Andy.
SCT tuner
RC tune
6 speed pedals
T56 tranny
T56 tranny bolts
T56 tranny mount
Floor tunnel
Clutch master and slave
Clutch
Flywheel
Clutch pedal safety switch
Shifter
Shifter bezel
Driveshaft
RC engine wiring harness*
*Depending on whether or not you care about running your own wiring for your reverse lights, you may not need the RC EWH.
I am. Shipping may be killer tho. Let me know what you gotta have for it.
Thanks man yeah I got a few drive shafts to choose from so I may can fab that, I don't mind the wiring so that's not too bad. When you say floor tunnel I was assuming the bottom of the floor kinda had an indention for the hole I needed to cut?
Right now I got a few folks offering up pedal assembly so that should be an easy grab. I'm guessing the clutch safety switch is on the pedal?
I got a yellow fever boot and bezel, I need a console and steering column shroud. I also need the hard parts, Trans, master and slave, clutch and flywheel.
I have the unleashed SCT so I'll have Torrie email me a safe RC tune for my truck when done.
On the mount is it a different cross member all together than the auto? Or just the rubber mount?
Lastly you say Trans bolts, will my auto bell housing bolts still work? Not that it's hard to order bolts but that's bout all I can think of.
Tons of help man thanks. Sounds like one of the easier swaps I've done. Lol. 12v Cummins in a 53 international was so far toughest. Btw who is Andy?
Streetgliderx Btw who is Andy?[/QUOTE said:A: Vprpwrd
A mild mannered reporter for a great metropolitan newspaper.
Well looks like the Trans is gonna be the killer purchase.
