Leveil22
Ok thanks
your QC has 4.56 changing to 4.10 would drop highway rpm some. not sure how much! maybe 300 rpm in high gear. easy swap . going taller yet, like 3.91 ,would require a carrier change as well.
Here you go. I will double check them this weekend, but I believe they are correct.
4.10 = 1810.0
4.56 = 2055.0
4.88 = 2181.6
5.13 = 2316.8
5.38 = 2471.4
How about the RPMs you would be turning at 80mph in 6th with the listed gear ratios?
4.10 = 1810.0
4.56 = 2055.0
4.88 = 2181.6
5.13 = 2316.8
5.38 = 2471.4
Make sure you take tire diameter into consideration!! 45 series will throw off calculations. Also someone with new tires versus old tires. Does make a slight difference. Ill see what mine says. I have 45s out back and 40s up front.
You're kinda right... If you are getting your mph reading off of a GPS, then yes it will throw it off. Although if you are running 45's, you will be going faster but your speedometer will not know the difference.
4.10 gears @ 80mph = just over 1600rpm in 6th gear...seems you're a couple hundred rpm off bud
4.10 gears @ 75mph = 1500rpm in 6th gear...
My truck has stock size tires (305-40R22's)
way to tell him 6 years later hahahahah
everyway i do the math on your truck cody it says it has 3.73 for a rear end
my loaded tire radius might be off as well
If it's within in inch, that should get us close.
A GPS will show the correct MPH regardless of tire size. The speedometer will read differently with a change in tire size.
Ya'll do realize that calculating RPM, speed, gear ratio, flux capacitor readings, etc, is as simple as using a basic calculator (click here for an example), right?
I haven't told you that since yesterday, Lil GuyHow many times have you told me that haha
Gotcha.Lol. Sorry bud I knew what I meant just may not have sounded right. --- MERRY CHRISTMAS GUYS!!! Thanks for all the helpful info and entertaining threads on my first year with the VTCOA!!!
