that is if u allready have the device in your truck, "INSTALL"is the word I missed:marchmellow:Ironhead said:has anyone installed the uconnect to there rb1 or rb4 radios,,i have a question if there is anyone who knows this system
thanks...it was a blast... 101 in calabasas around to 118 in simi valleyandrew heywood said:I just watched your run with the exotics,WOW, freeway looks mighty familiar, its in cal south ? bad as# vid:rock: :rock:
TheMoparConnection said:whats your question? i installed the full factory set-up, I know all about the U-Connect system
can you take pictures of what you're taking about? do you have satellite radio?Ironhead said:ok i have the setup and when i go to plug it in the radio do i remove the smaller of the two grey plugs to plug it into deck ??,,and if i do were does or what does the smaller grey plug go to that was in there to begin with ??
TheMoparConnection said:can you take pictures of what you're taking about? do you have satellite radio?
only one cable came with it ,,,has the grey small male plug on it and a black male one that plugs into the silver box ,, ,,,i think i would need a cable with a grey female plug for truck plug that goes to box and one that goes from box to back of radio ?TheMoparConnection said:it should of came with a harness that the dash wiring plugs into the connector and then the harness plugs into the back of the radio. Its a piggy back harness
if you got the instructions from Wolf its page 1. if not send me your email
