Scrambler1
Well the truck is up and running and spent some time on the dyno. Two other guys, FstJack and RamfromHell, finished similar setups about a month ago. Both of them could only build ~4lbs of boost and maxed around 650rwhp. My results were very similar to theirs.
Rough engine specs are as follows...
522 Stroker motor
9:1 Compression
Custom grind cam
Full head work (very close to Stryker flow numbers)
Crower roller rockers
Port matched intake with X-metal throttle body
Paxton supercharger with custom piping and intercooler (stock pulley)
We only made one full throttle pull, hit just over 4lbs of boost and only 630rwhp. My numbers are a little lower than Jack and RamfromHell but since I already knew their results we did no more tuning. I got the same boost they did... aka not nearly enough. There was more power left in it but I doubt that it would have broken 700hp. Boost jumps up to 4lbs and stays there.
I think the three of us have established that the Paxton just does not move enough air for a big built motor. The additional internal volume with the extra flow from the heads is just too much for it. If you want big power from a Paxton, forge the motor, VERY minor headwork, stock cam, change to a smaller pulley, and plan on spraying a 200 shot on top. This should get you to 1000hp but build beyond that and you actually lose power.
New build plan coming in another thread.
522 Stroker motor
9:1 Compression
Custom grind cam
