Texas Yellow Fever said:Maybe I'm missing the whole point here, but why would you essentially go backwards by introducing inefficiency. Isn't the whole reason we spend all these $$$ on engines etc to get the most air through them possible all the while making the most HP possible? The better answer is step up and fill the void that has been created...:burnout:
You may have missed the first sentence of my original post.:dontknow:..... "Yup, more boost (with a higher capacity turbo or a s/c would do the trick) and that is correct, the fact there is less "back pressure" indicates throughput assuming everything is working as it should"..
Tony's analogy with the big pipe/small pipe is true.
Velocity produces torque and smaller passages produce velocity (torque) up to the point where they become a restriction and the potential for increased horsepower falls. Horsepower is ONLY torque measured over time....right?...
And by doing what I suggested, you aren't really introducing inefficiency. There is already too much volume in the intake system for his Paxton (coupled with an early pressure drop with the performance cam). With a manifold swap and valve lash change, you are just encouraging the production of some usable power, that's all.
Complex subject ...
Happy Holidays!
Rotten
