1000hpOdyssey
- Joined
- Jan 4, 2007
- Messages
- 138
- Reaction score
- 0
I have not posted in a while because my engine is in the process of being re-built due to my previous builder having sloppily set the various tolerances up all over the place.
Everything was a mess, but the biggest single problem was the piston clearances. They were set too tight (.004 instead of .006).
As part of the new build, I am going back in with Pro Gram main caps so I will have the option of going turbo for more horsepower in the future. My new engine builder has developed a really cool way to achieve perfect line boring. :rock: See pictures. The line boring shaft is made from tool steel and has holes drilled in it to set the cutting blades. The copper colored rings are sleeves that can be moved around to keep the shaft absolutely straight throughout the cutting process. I want the crank to be set as perfectly as possible so it will stay absolutely where it belongs. This system is the best I have seen.
Hopefully I will be able to finally break the 700 hp barrier with a roe blower.
To that end, I have removed the roe restrictor plates and changed my cam selection. Thanks to the members that have sent pm's asking about the progress of my new build. I will be doing some additional posting as the build progresses.
Happy Holidays
Happy Holidays
