Features
* Easy-access loading ramp
* Tilt-out fender allows vehicle door access
* Ratchet-operated tire straps
* Vehicle security chains
* Automatic hydraulic surge brake
Capacity
* Max load: 5,290 lbs.
* Gross vehicle weight: 7,500 lbs. max.
* Empty weight: 2,210 lbs.
Towing vehicle requirements
* Must be equipped with a hard top if it is an SUV. U-Haul does not allow any type of sport-utility vehicle not equipped with a hard top to tow U-Haul equipment.
* Must weigh at least 3,500 lbs. (curb weight), and must equal or exceed 80% of the combined weight of the trailer (2,210 lbs.) and the vehicle being towed (up to 5,290 lbs.).
* Must have a towing system that has a 5,000 lbs. minimum weight-carrying rating
* Must have 1-7/8" or 2" hitch ball (5,000 lbs. minimum)
* Must not exceed maximum allowable hitch ball height 25"
* Must have external mirrors on both sides
* Must have fully operational lighting
* Auto transport lighting must be operational at all times, day and night, loaded or unloaded
* Maximum recommended speed is 55 MPH
* Load trailers heavier in front.
* Reduce normal driving speed.
* Wear a seatbelt.
Towed vehicle requirements
* Must not weigh in excess of 5,290 lbs.
* Must have a maximum outside-to-outside tire width of 79.25" Note: outside tire width over 75" must use late-model U-Haul Auto Transport (identifiable by silver galvanized color).
* Must have a maximum wheelbase (distance from front axle to rear axle, usually posted on the driver's side door jamb) of 133 inches.
* Low-hanging equipment on the vehicle being towed such as spoilers, air dams, ground effects, etc., may be damaged by contact with the Auto Transport during loading and unloading. Make sure there is enough clearance for these items.
All truck and trailer measurements are approximate. The equipment you receive may vary in size, based on the engineering/design specifications of multiple-production models.
