Installing 4.56 gears in an 04 question
LitemUp
The Looney Bin
Ok purchased a used set of 4.56 gears from a member before installing them I have a couple of questions.
1. Is the ring gear a direct bolt-on to my carrier?
2. If not, what size spacer(s) do I need to make it work?
3. What's the part numbers for the crush sleeve and bearing? I might as well replace them since I'm already there.
Thanks,
Alex
Should boltup to the carrier. Suggest you use new bolts . The pinion is shimmed both sides. Alldata has a Good procedure to follow . You may need a shim kit. Did you get the shim kit with the gears?
Will bolt up. Does not use a crush sleeve. Would suggest buying the installation kit from MoPar for the correct shims.
Like someone who knows a lot about rears told me, don't buy used gears.....
