When I had my '05 QC, I removed my wing, and there was a thin rubber "gasket" under the surface where the wing sits on the bed. It was glued to the wing.
Don't have any pics, but it's only 1 bolt under the rail on each side then either push spoiler forward or backward (only did it once, so can't remember which) as there is a pin on rail that slides into a slot on spoiler that helps lock it down and then lift it off. Fairly easy procedure.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
