VENOMOUS1 RACING
Well I made the next addition to my Quad Cab and that's the 1 piece aluminum driveshaft!:drool::rock: Still need to get the final weight, but I am guessing around 28 lbs compared to 42 lbs! That's one hell of a loss in rotational mass! There is also another 10 lbs. of total weight removed from the truck as the crossmember that once held the crappy carrier bearing is removed for clearance of this Monster Driveshaft! It makes 6th gear in my Manual tranny respond more like 5th gear! With the autos you can expect Crisper, Firmer shifts due to the lighter shaft, as well less throttle input to acheive the same acceleration!:rock: This shaft is able to withstand up to 1000 HP and over 1800 ft lbs torque:burnout: It has a torsional torque rating of 7200 ft. lbs.!
It consists of heavy duty U joints and a new tranny yoke as well as billet HSA High Strength Aluminum driveshaft yokes that are the same diameter
of 5 inches as the entire driveshaft! If you notice most are smaller 3 inch yokes and taper into the 5 inch shaft size. This is one size throughout the entire length of the driveshaft. I have made measurements on this as well as the normal Auto tranny version which will obviously be more popular of a mod.:rock:
PICTURED BELOW FROM LEFT TO RIGHT: QC SRT 10 -Toyota Tundra-(steel) -Ford F-150
