Selling my X-Metal Gen X shifter it has been modded to reduce the rattle that usually is common with the aftermarket shifters. Shifter works flawlessly the only reason why I'm selling it is because I got a new Venom Shifter from Tony.
Shifter will come with all bolts as seen in pics. It will also come with custom leather shifter boot (longer than stock) and stock bezel (it was done because I didn't like seeing the bolts on the Jedi lever).
Shown here is the custom rubber isolator and metal plate that helps reduce the rattle.
Larger bolts were used with nylock nuts as well to make sure that everything remains nice and tight.
Nylon washers were used on the bolt on the upper handle to further reduce noise.
To mount to the tranny you use your stock bolts and your stock shift knob also screws right on. $175 plus shipping
