Royal Purple Ice
trussman
Jacksonville, NC
Anyone use Royal Purple Ice? Does it work? If so, how much is needed for the size of the cooling system?
I use it in quad and works VERY well!! Got very high compression and used to get SUPER hot before i put that in. I just put a hole bottle in and filled the rest with water. For our trucks id imagine a couple bottles though lol
Yes I did . hahaha Your welcome..
I have never tried it ,, Someone else may have though .....
Let me know if you buy this. I can sell you a board stretcher. If you pay shipping I will throw in a bottle of blinker fluid if you want to go with custom head lamps.
I bought 5 cases. The label says it stretches boards and can be substituted as blinker fluid. Used to treat smart a$$ syndrome too
It changes the surface tension of the water.yes it works.used a similar product water wetter in my racing two strokes in the past.
i had coupon for a free bottle. figured it couldnt hurt. I put it in with my 170 thermostat today.
I used it and seen absolutely NO differance in cooling temps period. I also used watter wetter in the first cooling flush and seen NO differance.
Maybe if you were using only water in radiator it would help over water alone But who is going to do that?
I changed my t-stat and added this in when I topped it off so full results can't be given credit unfortunately. It stays right at 175ish unless I'm romping on it a while. I did notice though that it seems to cool down faster than before which is worth it for some hot laps at the track later.
