- Joined
- Feb 26, 2008
- Messages
- 9,775
- Reaction score
- 7
Take the sims out and check the wires really good. I believe the passenger side O2 sensor wire is harder to check since it runs to the top of the tranny.
was not raining when it happened and i didnt wash the motor down...
More updates:: found that fuse #2 30a engine control relay, asd spare is blown
when replaced with another 30a fuse it blows right when the key is turned.
does anyone have a wire diagram to this fuse so i can check for bad wires?
what wire is blue with white stripe in the lowest plug on the ecm? I looked in the wire loom and it was repaired once, but it looks to be done well, but might as well confirm what wire it is.
Would fuse 49 (o2 sensor fuse) blow if it was an o2 issue? I know that its inline with the ecm/asd fuse
Be careful not to start throwing money at it with this sensow and that sensor. Save yourself a headache and have a good shop or the dealer check it out. Might cost ya 90 bucks but it is better than replacing tons of small stuff that doesn't fix your problem. Diagnosing over a forum prolly isn't the best route with electrical issues. I'm sure I'm not the only one who will wanna know the outcome once u find the prob. I have done the parts replacement game with vehicles in the past. Just get it checked out, you won't regret it.
This might be the easiest way to go. Whats a full day (or more, maybe with parts) worth to you?
At some point you have to say screw it and take it to someone. How is the dealer that sold you the truck?
MAJOR UPDATE ha::
Went outside and pulled the o2 relay and the fuse didnt pop... put the o2 relay back in and the fuse didnt pop... did the key sequence and it now worked and said done in the odo so the computer is back up and reading....
I dont have enough fuses right now to complete the fuse box or I would try and start it.
I AM STUMPED! I can almost promise that if i had all the fuses it would start right now. I did wiggle a lot of wires, but as of now the short is gone *insert puzzled face here*
I have seen some really crazy crap that made no sense before.
yea, but you still have trouble![]()
