Digital Torque Wrench - Member Special
BLMW
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: VTCOA
You can see the torque wrench in action in the following video:
[ame=http://www.youtube.com/watch?v=cEJsE2vlxxE]Brown Line Metalworks Digital Torque Wrench - YouTube[/ame]
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until April 15th, and is only for the lower 48 states.
What Country is it Made In???
The ratchet and the steel components of the wrench are manufactured in Taiwan, and the electronics and assembly are done in Malaysia. Our repair / calibration facility is located in Chicago in case anything ever needs to be done to the wrench.
BLMW
Great question
BLMW
How durable is it? E.g. shock load withstand, temperature, overload. My tools seem to hit the concrete when I use them...:dontknow:
First, like any torque wrench, it is a precision instrument. It should be handled with care.
That being said, the best thing I can say is that we have had very few issues / returns from units that are out in the field being used everyday. The unit can handle a lot.
BLWM
Need a torque wrench? We have one for you!
Mine arrived yesterday evening. It was even nicer that I had expected. A quality tool indeed. I like the case it comes in too.
Now if you could just come out with the 3/8" drive version......:)
Thanks for initial review. If ya can, maybe you can fill us in on its real world functionality in a more in depth review later :D
