what else can i put on it?
AdrianCaF91
i already have a mopar catback and k&n drop in , roe tuned what else can i put as in bolt ons that helps these trucks out the most?
Throttle body would be an easy way to improve power as well.
I have the JTSVP TB, but others like BBK and ROE also have
something to offer.
With the search function you will find some results on
HP measures between the TB`S.
Have fun !
One of these!!!!:D
[/IMG]
In addition to everyone elses suggestions try an underdrive pulley and shifter.
Catch can(s), powder coat valve covers, intake, brackets ( Justin at JMB does amazing work) change out your reservoirs for some powdercoated ones, change out your grill, it's endless!! Lol
Stop now!...... Before your wife hates you. :D
If you plan on going to the track with it I say go now with what you have. That will give you a starting point. Then do slicks or drs and some traction bars and work on getting your time down that way then mod it up from there.
Ps don't forget to fix the things that break
I second that, time with you behind the wheel of your truck is going to be the most beneficial and it only costs your time.
