Sean & Josh
NVR2OLD
VTCoA Senior Member
Rapid City, South Dakota
Thanks Sean & Josh for all your help on my rebuild for my motor. I'm sure with the added power I will enjoy my truck even more.:D
Forded Rotation Assembly with Diamond Pistons and Callies H Beam Rods.
Total Seal Ring Kit
Clevite Main & Rod Bearings
710 Cam
High Performance Lifters
Upgrade Valve Springs
5 Angel Valve Job
Had a friend Port the Heads
Upgrade Pushrods
Upper & Lower Gasket Kits
Thanks...Andy
how much did all that run you with labor?
Almost $12,000 with machining, parts and labor and new crankshaft. I also added a power force + damper, coils, wires, plugs and software for the SCT programmer.
Sean and I are still working with the tune, but still running rich. Hope to get the truck on the dyno soon and sort out the fuel. The sound of the 710 cam is great. Will let you guy's know how it turns out.
With parts and labor and knowing that ROE will take care of you, that's not bad.
