Tear Jerk
I bought my truck about a month and a half ago and recently took it back to the cadilac dealer to have what i thought was a rear main seal replaced. They then notified me that it was the trans that was leaking so they sent it to a trans shop. The shop diagnosed it as the input shaft seal that was leaking. While they had it apart i asked them to check the clutch and replace it if necessary. They then said the clutch was bad along with the aftermarket flywheel being shot. They supposedly replaced the clutch flywheel slave cylinder cable fluid and the seal that was leaking. Before my clutch took a little effort to use and now the new one feels like you could use a pinky finger to push it down.
My question is what type of feel is it supposed to have with a stock style clutch bc if they used cheap stuff id like to know. Thanks
