Considering separating portions of the truck
Ram From Hell
Bremerton, WA
Having little success with the sale of the truck as a complete package, I'm giving thought to returning key items to stock, and selling off some parts:
Rear axle: DTS built, Wilwood discs, Currie axles, cryo'd 4.11 gears, bearing support cover, never a problem with bearing leaks. Approx. 1400 miles.
Drag pack: bolt-in cage with swing-out for driver's side, seat, harness, window net, chute, Bogart fronts & rears, 2-pairs of 10.5 Hoosier slicks (fronts are new in boxes w/o tires, rears have one of the sets of Hoosiers mounted with bead lock bolts).
Procharger F2 kit: complete (can include fan kit and modified power steering line, with clean factory parts in exchange). Extra pulleys for different levels of boost, and a spare belt. System has about a dozen dyno pulls, about as many passes on the track, and less than a few hundred road miles. Should probably bundle the FJO water/meth kit with this.
Engine: sheet metal intake by Hogan's Racing, Striker heads with Jesel valve train and Inconel exhaust valves, Cometic head gaskets, Oliver rods, new 2005 model crank, Diamond pistons with ceramic coatings on top and wear resistant coatings on the skirts, 9:1 CR, coated main and rod bearings, ARP studs and fasteners throughout, ATI superdamper, modified oil pump, 1000CC Bosch injectors, Maganafuel boost-referenced fuel pressure regulator, modified AEM ECU and harness (pass through for all dash instrumentation) and a pair of AEM serial data gauges. Engine yielded over 600hp with factory intake and engine management. Just need a solid replacement as part trade, unless I've already found and installed one. The engine has about 1400 miles, a couple dozen 1/4 mile passes and about as many dyno pulls. If I'm not mistaken, I believe there's about 28k in the above.
There are a few other things, like a twin disc McLeod (new), and I can also sell/swap my triple in-tank Walbro fuel pump with a factory.
That leaves the truck, which will be complete and fully functional, with fresh paint, Venom hood, shaved antenna, grill inserts, smoothed and tinted tails and 3rd brake light, custom wheels and tires as well as the original wheels and a new set of Pirellis. Lots of other stuff like Gen X shifter, MGW billet stuff, HID headlights and driving lights, brand new bed rug, Caltracs, Magnaflow exhaust, vented front discs, lowered, QA1 shocks, new front and rear wheel well liners, driveshaft safety loop, etc. I bought this new off of a local lot, and still have the original window sticker.
40k for all of this already put together, but I'm probably better off doing it this way.
Send PM's for interest in the parts or truck.
What kinda deal on the motor / charger and all goodies to plug and play,.
Were only a couple hrs apart, just do a swap, mine for yours, yours for mine and some cash
Just to clarify things here, I'm separating out packages for purchase. This is a de-mod, not a parting out of the truck.
Please bear this in mind when sending messages. ;)
Do you have any way to compare the weight of the DTS rear end as compared to the factory rear end (including brakes)? Also do you have a set of 4.56's to go in the DTS? Do you need a stock rear end as exchange? I could drive up to you with my SRT-10 if we need to exchange. ( I really need the 4.56's as I'm still NA).
It is a 4.56:1 ratio. I don't honestly know how much weight savings the DTS represents over stock. I still have my stock rear axle, so no exchange is needed.
6499 for the F2 kit.
6999 for the F1-C
So, given that mine's fully optioned, it would be over 10k new, plus the modification of the power steering line. Mine would also come with a fully optioned FJO water/meth injection system, with mappable controller and 1000hp injector.
Bear this in mind when making an offer. :rock:
