looking for new racing rims and slicks
moparviper
Shreveport Louisiana
I want to run some slicks next year and know that i need at least a 16 inch rim. does anyone have a good combo out there of 16 inch rim and some slicks?
Thanks
Nick
You have CCW 16" rear and 19" front that fit with minimum grinding to front calipers.
Then Bogart has a few designs in 16" rear and an 18" front.
You can go Eagle/Pacer/American Racing but they will stick out a bit.
I bought bogart 18 inch front rims from a member on here a couple weeks ago. I guess ill take a look at a bogart 16 inch rear rim then. Any suggestions on what slick to use?
So i just got on the bogart website and see that just about everything is custom made. And usually custom made means expensive. Im gonna look at different options lol
I recommend the M&H Cheater slick 30/14.0-16LT and the Bogart 16x10 to match your front wheels. Bogart has the correct offset. That's what I'm running, one of the quickest NA trucks on this site (11.631 @118.01) and I usually have a 60' in the low 1.60's. My best is 1.57. I am leaving at 4500 rpm with no wheel spin (16.5 lbs).
Bogart is the best, I'm actually picking up a new set to try on mine now. He got the front measurements on mine figured out so now the fronts fit without changing the front calipers. Send me a pm and I can put you in touch with Rich.
Bogarts are nice but $450 per rim, I use procomp alloys they were like 130 a rim
Pro Comp Xtreme Alloys Series 1069 Polished Wheels 1069-6185 - SummitRacing.com
Bogart has actually done extensive measurements on my truck and these last wheels he has mocked up for me should fit good.
Do thoes rims stick out at all? And do they perform better then the bogarts?
Btw thanks for the link!
Yeah they stick out a lot, they weigh more than a bogart but not sure how much. I pull consistent 1.6x 60' times with my setup. And overall they are $600 less than the bogarts
I run a 28x14.5x16
Can u post a pic from a backview seeing how.much they stick out. Im trying to get a idea of how much cause with a cut rear end i would still like to make some passes down the ET
Sent from my SGH-T959V using Tapatalk 2
Can't find any pictures but they stick out about 2" on each side
