Drive Shaft Loops Group Buy
JTS VENOM PERFORMANCE
Preferred Vendor
SRT10 heaven
Cherry performance drive shaft loops sold by JTSVP now
This NHRA compliant safety device keeps the drive shaft from digging into the ground and reduces the chance of cockpit entry in the event of a drive shaft breakage.
This is a bolt-in application for the 2004-2006 Dodge Ram SRT10 Regular Cabs and 2005 Quad Cabs. This item bolts to an existing support and requires no drilling or welding. This is a must for tracks that require a safety loop for trucks running faster than 13.99 in the quarter mile. The loop is constructed of 0.250" thick steel. Drive shaft safety loop includes all mounting hardware and installs in 30 minutes or less using basic hand tools.
Key Features:
• Bolt-On Design Allows For Easy Installation With No Modifications Required.
• Removable Loop For Easy Driveshaft Removal
• Adjustable Loop Locations For That Perfect Fit
• Meets The Requirements Of All Racing Sanctioning Bodies.
• Will Help Contain The Driveshaft In The Event Of U-Joint Failure.
• Manufactured From ¼†Fabricated Steel.
• Durable, Black Powder Coated Finish.
• All Hardware Included.
Item #CP-RCLOOP Regular Cabs $100.00 plus shipping
Item #CP-QCLOOP Quad Cabs $135.00 plus shipping
Will need a minimum of 10 each. You can pick a standard powder coated color if you do not want Black for the Group Buy.
post up or contact us for payment
I just got mine this week and hopefully will be installing this weekend. :D
I'll take one too. Did u get urs at group price?
Would this work on a modified truck that has a one piece drive shaft?
How wide are the straps on the loops?
Key Features:
Just got mine installed. Added a bushing to give it some stability. To bad this work of art is not visible for all to see.
I have an 06 QC. If this will fit a one piece drive shaft sign me up.
I believe it will, SRT2Slow has a one piece driveshaft in his truck and has the same loop.
