Oil leak/dirt normal for 71K mi?
smackdownSRT10
Haven't had a used car with this many miles on it in a while. Here are a bunch of pics.
Just replace my oil lines with 72k on the odom. My engine bay doesnt look like that....but my oil lines did. Get some simple green and spray that entire bad boy down and clean her .....and get some oil lines made or buy some from one of the vendors here ;)
Bought these off a member here
Pic with 72-73k before lines were replaced.
Easy install no part number check jmp or another vendor its simple google search instructions I'm doing mine this weekend
I got those same lines, awesome construction and no leaks!!!!!!!!!!!!!!
Which are they? Looks like it says Gates.
Gates is the company who makes the lines(by the foot) I just went thru my PMs and my comments from the memeber I got these lines from. He is a Canadian member and did a great job on these. Way better than stock and way cheaper than braided fancy ones like Titos :D Another option is to take the lines off to the nearest parts store and alot of them custom make lines for very cheap.
Not so much a Parts Store as a Hydraulic Supply Shop. Check the Yellow Pages.
I have had an old set of lines to auto parts stores, hydraulic hose shops, you name it and not one single person around here can make them. They claim they can't make the flare on the end.
The leaky lines are common, actually they are cleaner than some I have seen... the engine bay itself is in need of some TLC
For the pricing I'm seeing on them, I probably would.
