Power Steering leak but not a lines??
THEWELSHM
Well-Known Member
Brandon Florida
I have Tonys lines on my truck but I have fluid leaking on to surpentine, but cant seem to find from where:( Anyone else ever experienced this?
thewelshm
I had a power steering pump go bad on my truck, when it runs out of fluid the engine overheats because the power steering fluid drives the cooling fan.
Could be spraying from any of the line fittings even at fan module and causing belt slippage/noise. I'd top it off and have someone slowly turn wheel left to right with truck running. That should show the leak area sir. :rock:
Found the Biatch:rock: an o ring had broken on the blue aluminum fitting, under pressure spraying all over the belt.
thewelshm
