06SRT10
I went to: http://www.dodge.com/wccsapp/univers...ull&category=U. Filled out the info & the next day Dodge emailed me my build sheet.
Great info man! :rock:
Didn't work for me. I put my VIN in the search bar and got the following message:![]()
"There are 0 pages that reference 3D3HA16H64G220576.
Sorry. We couldn't find what you were looking for.
Try checking the spelling of your search of searching one of the sites to the right."
Equipment Listing
VIN 3D3HA16H64G220576
Vehicle Description 2004 DODGE RAM 1500 REG. CAB PICKUP
Monotone Paint
136 Amp Alternator
Front Height Adjust Shoulder Belts
Passenger Air Bag On/Off Switch
Next Gen Multistage Front Air Bags**
Floor Covering Carpet
Passenger Assist Handle
Behind the Seat Storage / Bin
Tinted Glass Windows
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
Remote Keyless Entry
Dash Liner Insulation
Floor Tunnel Insulation
Route 53 - UP, Kent, WA
Instrument Cluster w/Tach
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Glove Box Lamp
STANDARD EQUIPMENT
Halogen Headlamps
Cargo Lamp
Front License Plate Bracket
Dodge Badge
Removable Tailgate w/Caliper Latches
26 Gallon Fuel Tank
Speed Control
Black Clear Coat
Tilt Steering Column
Tire Carrier Winch
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6750#
U.S. Dealer Retail
Zone 71-Los Angeles
Two Wheel Drive (2WD)/(4X2)
6 FT. Cargo Box
Regular Cab
1500 Series
DR-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
Washington Ship to State Code
Washington Sold to State Code
Leather Seats w/Perforated Suede
Dark Slate Gray
OPTIONAL EQUIPMENT
Light Group
SRT Group
Security Group
8.3L Eng(EWC)/6Spd M/T (DEC)
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Perf Brakes
40/20/40 Split Bench Seat
Supplemental Side Air Bags
Supp Side Curtain Front Air Bags
Front Floor Mats
Front Center Seat Cushion Storage
O/Head Console w/Trip Computer/UGDO
All Manual Transmissions
6-Speed Manual TREMEC Transmission
4.10 Rear Axle Ratio
200MM Rear Axle
Anti-Spin Differential Rear Axle
8.3L V10 SFI Engine
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
All Vehicles W/Power Mirrors
Satin Silver Lock Knobs
Sentry Key Theft Deterrent System
Air Cond'ing w/Dual Zone Temp Cntrl
Instr. Panel Sport Bezel
160 MPH Primary Speedometer
Black Clear Coat - Molding - Sill
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Fog Lamps
Security Alarm
Body Color Grille
Hood Power Bulge
Body Color Front Fascia
Body Color Rear Fascia
Ram SRT10 Badge
SRT10 Badge
Viper Powered Badge
Rear Bodycolor Spoiler
50 State Emissions
Federal HDV1, Cal. MDV 1 ULEV II
Bright Exhaust Tip
Dual Rear Exhaust w/Bright Tips
Maximum Duty Engine Cooling
Black Clear Coat
All Radio Equipped Vehicles
Uconnect 8.4N CD/DVD/MP3/WMA/MW/FM
8 Infinity Speakers w/Subwoofer
Fixed Long Mast Antenna
508 Watt Amplifier
Steering Wheel Mounted Audio Ctrls
Performance Steering
Leather Wrapped Steering Wheel
Front Perf Tuned Shock Absorbers
Rear Perf Tuned Shock Absorbers
Rear Perf Tuned Stabilizer Bar
Front Perf Tuned Stabilizer Bar
Compact Spare Tire
P285/40R22 BSW All Season Tires
Pirelli Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
22X10.0 Aluminum Polished Wheels
Power Adjustable Pedals
Bright Pedals
Hurst Shifter
Under Rail Box Bedliner
Manuf Statement of Origin
2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM: DR TRACKING: 30910M09AA MY:2004
FAM: DR TRACKING: 204SRT01AS MY:2004
FAM: DR TRACKING: 30910M09AC MY:2004
Customer Preferred Package 2TS
Customer Preferred Package 29S
Schedule D To C Tracking
Pre-Spec Vehicle Order Tracking
Distribution Services Tracking
Waterbase Paint
Paint Order Code
I have been able to print this list off the net before. What does the build sheet Dodge sends out look like....I know it's not the original window sticker but it might be better than what I've got.
Side note. With my VIN, do you have the capability to contact orginal owner to see if they have original window sticker?
No
and the build sheet you get from dodge is formatted a lot better (at least the ones I've seen) and includes a lot more. Worth the time, yes
With a Vin I can get an electronic build sheet
Sorry about the tire size, I can't fix what's in someone else's DB
Lol, no apologies, just wonder if they possibly came with those too. :dontknow::burnout:
The build sheets (I've seen) that come from dodge just show " PIRELLI BRAND TIRES" So it's fixed there. I just hesitate altering what I get because I know someone out there will bitch that I altered data maliciously. At some time in the future most will only know what they see in electronic resources and knowing the errors exist give the RAM SRT-10 fan a leg up on facts and what is published
Thanks, Jeff!Does what seemingly impaired caveman cannot.
Negative. My truck was originally a Vegas truck.That one you posted shows Cavemans truck came with Pirelli 285/40-22 tires? Was this maybe offered to Northern trucks ?
Jeff, sorry I posted this. It looks like it is causing you extra work. It has worked fine for everyone out here. Don't know what the problem could be.
