How come no one has documented and posted pictures of a clutch change?
Cudajon
Oklahoma City
Got a three day weekend so I'm going to tackle it. Someone whose done this, do I have to pull the exhaust system?
I didn't have to remove exhaust last time I had a trans out. Of course that was a 6 speed QC.
Yes sir you do.
Nah, not if you have a V1R side exit setup sir :rock::burnout:
Otherwise yes you'll have to remove from flanges, and hangers and move outta the way sir.
Otherwise remove driveshaft, bolts from tranny mount, tranny to bellhousing, remove hydraulic line disconnect , remove tranny, then bellhousing. Check pilot bearing and add a lil heavy grease to end of input shaft where it enters pilot.
I'll guide ya when needed sir. :rock:
DRAIN THE OIL!!! or it will all endup on the floor! or on your leg!! real messy!!
