gregalc
Do the header bolts usually come with their headers? I have the clamps and gaskets but no header bolts or collector bolts?
honestly I would run the arp bolts, they are stainless and no rust,
but they are 5/16 x 18 x .750
also I would use oem gaskets instead of the ones they use
but if you call lou or jerrian, they will most likely take care of you sir
I bought my headers used-unopened still in box-but nonetheless, used. They came with triple gaskets from mopar. Is this not what usually comes with them?
I appreciate the info on the size of the bolts-I'll probably go with the arp's after all the positive feedback I've heard about them.
totally stainless has a great header bolt/lockin washer:rock::rock::rock:
I really like the looks of those...
have givin me great service.
installed with a dab of anti-sieze.
have checked them a few times over the years/miles, never had a loose one:rock:
might want to check out a heat sheild for the starter, also.:dontknow::rock:
Is that usually a problem or is it a piece of mind mod and where can I find one?
