Newfie-SRT-10
Pull the white cap
And yes, it is factory
It's hard to see because the pictures so grainy but there are only two wires, pink with a yellow stripe. I'm not sure if both wires have the yellow stripe, or just one.
I didn't see that connector under there but...
By the ignition switch I started playing around a bit. Found main power then started touching other wires to it and started getting stuff working.
I ended up putting them 2 wires pink with yellow stripe and pink with green stripe together and everything worked so I just taped them together.
I assume that fuse in the block is bad I will look again tomorrow for it. But it solved every problem even speedo and abs. Whole system is up and running good now
Thanks for the help
