Power steering pump removal help.
mcdoogle1975
Frankfort, N.Y
Hi, newbie here from upstate n.y, just purchased my 04 black supercharged RC 2 days ago. On the journey back to ny from new jersey I blew a power steering line. Long story short I just ordered JTSVP lines to install but my question is, what it the easiest way if there is one, to remove my ps pump so I can replace it with a new one. Rather be safe now then sorry later........ any help would be greatly appreciated.
Thanks in advance
Thanks in advance
No easy way lol. Did you buy the 2 tone one that is completely built.
If its the black and red one you are talking about then yes. I took a look at it after work today and it looks like I have to remove the ac unit...... is this correct?
Quite the impressive build......crazy power!!!
Power steering pump is easy, don't make it too hard on yourself, a 1/4 ratchet small extension with a 13 mm socket, three bolts, you can go right thru the holes in the pulley takes about 30 minutes tops, easy deal man, need any help give me a shout tomorrow boss.also don't forget there are two hoses on the backside of the resevior to remove, held on with clamps
Yes sir you stole that truck for sure. Is it your first 10? Good luck with your purchase now let's see some video of that thing.
That is a fantastic truck you got there. I took a good long look at it for a member that was going to purchase it and it is so clean!! Congrats and good luck getting the power steering situation straightened out.
