Build Sheet
Jeff, sorry I posted this. It looks like it is causing you extra work. It has worked fine for everyone out here. Don't know what the problem could be.
I'm glad you posted it, even if Jeff had to make it work for me :eek:
Can you pull mine also? The site shows error. 3D3HA16H55G788111
Equipment Listing
VIN 3D3HA16H55G788111
Vehicle Description 2005 DODGE RAM SRT-10 1500 REG. CAB PICKUP
Monotone Paint
136 Amp Alternator
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Perf Brakes
Front Height Adjust Shoulder Belts
Passenger Air Bag On/Off Switch
Next Gen Multistage Front Air Bags**
Floor Covering Carpet
Front Floor Mats
Passenger Assist Handle
Behind the Seat Storage / Bin
O/Head Console w/Trip Computer/UGDO
4.56 Rear Axle Ratio
200MM Rear Axle
Anti-Spin Differential Rear Axle
Tinted Glass Windows
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
Power Heated Mirrors, Fold-Away
Satin Silver Lock Knobs
Remote Keyless Entry
Sentry Key Theft Deterrent System
STANDARD EQUIPMENT
Air Cond'ing w/Dual Zone Temp Cntrl
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Cluster w/Tach
Instr. Panel Sport Bezel
160 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Power 6-Way Driver Seat
Brt. Silver Met. C/C - Molding - Si
Glove Box Lamp
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Halogen Headlamps
Fog Lamps
Cargo Lamp
Security Alarm
Front License Plate Bracket
Body Color Grille
Ram's Head Badge
Hood Power Bulge
Body Color Front Fascia
Body Color Rear Fascia
Ram SRT10 Badge
SRT10 Badge
Viper Powered Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Front Air Close Out Panel
Rear Bodycolor Spoiler
Bright Exhaust Tip
Dual Rear Exhaust w/Bright Tips
26 Gallon Fuel Tank
Speed Control
Maximum Duty Engine Cooling
Bright Silver Metallic Clear Coat
8 Infinity Speakers w/Subwoofer
508 Watt Amplifier
Steering Wheel Mounted Audio Ctrls
Performance Steering
Leather Wrapped Steering Wheel
Front Perf Tuned Shock Absorbers
Rear Perf Tuned Shock Absorbers
Rear Perf Tuned Stabilizer Bar
Front Perf Tuned Stabilizer Bar
Tilt Steering Column
Tire Carrier Winch
Compact Spare Tire
P285/40R22 BSW All Season Tires
Power Adjustable Pedals
Bright Pedals
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6750#
U.S. Dealer Retail
Zone 35-Washington
Two Wheel Drive (2WD)/(4X2)
6 FT. Cargo Box
Regular Cab
1500 Series
DR-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
Maryland Ship to State Code
Maryland Sold to State Code
Leather Seats w/Perforated Suede
Dark Slate Gray
8.3L Eng(EWC)/6Spd M/T (DEC)
40/20/40 Split Bench Seat
Supplemental Side Air Bags
Supp Side Curtain Front Air Bags
Front Center Seat Cushion Storage
All Manual Transmissions
6-Speed Manual TREMEC Transmission
8.3L V10 SFI Engine
All Vehicles W/Power Mirrors
50 State Emissions
Federal Tier 2, Bin 10C Emissions
OPTIONAL EQUIPMENT
All Radio Equipped Vehicles
Uconnect 8.4N CD/DVD/MP3/WMA/MW/FM
Fixed Long Mast Antenna
Uconnect Voice Command w/Bluetooth
Pirelli Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
22X10.0 Aluminum Polished Wheels
Hurst Shifter
Under Rail Box Bedliner
Manuf Statement of Origin
2 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
FAM: JA TRACKING: 60816L00
Customer Preferred Package 2TS
Customer Preferred Package 29S
Waterbase Paint
Paint Order Code
You're Welcome, I just do my small part
Oh, and that build sheet is worth .000000158 increase in HP loss on the Dyno
Click on "Owners" and go from there
That site changes on a regular basis
GO TO CONTACT US ON BOTTOM OF PAGE AND THEN ONCE YOUR THERE TO THE LEFT YOU WILL SEE EQUIPMENT LISTING CLICK ON THAT AND THEN A PLACE TO TYPE YOUR VIN WILL APPEAR. i used large letters cuz if i didnt most would just ignore, i use this often, remember go to dodge.com then bottom of page click contact us then equipment listing then vin
Thanks, bottom of page, contacts, your vehicle tab, equipment listing tab, then enter VIN.
For the others, sorry i didn't think to look under the contacts tab........
Didn't see anything about contact tab........ I'm old, can't think for myself, need thorough directions so my sometimers doesn't kick in and make me for
at the very bottom in small letters it has different links and " contact us " is about in the middle, took me a while at first to figure it out but it works 99% accurate, i noticed on older models its not accurate at all like 1990s.
i was just mentioning that in the original post it didn't say to do that. i got it now, thanks again to all that helped
