FS: Procharger Setup, Gauges, McLeod Clutches, PLug Wires, JMB Fuel System, ATI, Cam
JMB Justin
Preferred Vendor
Hillsboro MO
Have a customer with a 04 RC going back to stock to sell the truck for a new project. Everything has about 15K miles on it. I will post all of this on ebay with pics and links tonight most likely, here's a breakdown of whats for sale, everything is in great condition unless otherwise noted:
-JMB F1-C 8 Rib Polished Procharger kit, 100% complete base kit, $7299 new, $5000
-ATI balancer (needed for above), $435 new, $275
-Dual pump fuel system (good for 1000hp) with all lines, injectors, modified stock rails, regulator, 100% complete fuel system, new $1905, $1300
-McLeod Twin Disc with Meba/ceramic lining, we have made 1400whp with these clutches, they are $1749 new, both from 04's, so they will fit all 03-06 viper engines. They are also rebuildable. I have two, one is in great shape, ready to go for big power, $1100, the other is from another truck, the top disc and the floater look like it has been slipped/hot, I do not know the history but came from a stock 27K mile truck so its not high mileage. $500
-JMB B62X cam, no issues, $675 new, $400
-JMB Power adder catch can with lines $309 new, $200
-JMB Plug wire set with seperators and high temp sleeves $289 new, $150
-Mopar longtube headers, no longer available new, $1000
-JMB Upper radiator pipe, red, $99 new, $70
-Mopar Viper Master Cylinder for clutch upgrade kits $250+ new at dealer, $125
-Triple pillar pod with autometer boost gauge and AEM wideband, new $359, $225
If someone wants the complete blower package with fuel, clutch, ATI, etc I will put together a package price.
You can text me at 314-540-1541 for pics if you don't want to wait for the ebay auctions. Everything has a fair price so please don't waste our time with lowball offers, etc.
Thanks
Do the Mopar headers include mid pipes?
Can you list cam specs.
B62X - 22X/24X duration @ .050 lift - .62X/.62X lift with 1.7 rocker 114 CL
This B62X grind is specifically designed for Blower applications that are full bolt on's with stock/mild ported heads in a viper car, 6 speed viper truck or automatic viper truck that also has an aftermarket 2500+ RPM stall converter. Recommended for 6-12psi. Requires upgraded valve springs and pushrods, we can provide these as well.
No just the headers, he had custom exhaust from there back which he is keeping.
Thanks
Justin
This is the truck thats getting put back to stock, so pretty much any aftermarket parts on it (not including the side exit exhaust) are up for grabs, and the truck will be for sale soon:
The great shape McLeod Clutch, ATI balancer, F1-C kit, and the dual pump fuel system all together Id take $7000/ and your stock fuel pump assembly/feed line. That's about $4500 off new.
I also have:
-SCT X3 with the tune for an 04 pcm for this procharger setup and fuel system
-ARP head stud set $200 (new $375)
Any idea if the catch can hoses and fittings fit directly on my 05?
Text replied to, the can has hoses for an 04, it would be $40 more for new longer hoses for a 05/06
They are still up on eBay. Or is that another set? :dontknow:
I took them down thanks
$600 on the SCT for the Procharger setup (tune is for the B62X cam too, and only for an 04 pcm), so that's $5k off new for the complete package ($7600 vs. $12,600 Clutch, ATI, Procharger, SCT, Dual pump)
