Wheel question
tourdemon
Hi all was wondering if someone could answer this for me. I would love to purchase a set of 2015 Jeep SRT Wheels, here is the size. Would they fit our trucks?
Wheel Size 22x9 +34 offset Bolt Pattern 5x5 or also labeled as 5x127 71.5 MM Hub Bore
i can't say for sure on the hub size but the biggest thing i can think of is you're losing an inch of wheel width and i don't know that i'd put a 305 on a 9" rim?
does that matter to you?
Dan's right. Although I think a 305 would probably be the max I would consider safe on a 9 inch rim for performance aspects. I think a factory Ram 2500 wheel is 9 inches wide and I know a few guys that are running 35X12.5 inch tires on those wheels and that's a half inch wider than our tires. Although they're not trying to hang gnarly corners at 80mph either.
Wait...... didn't you send me 15 inch wide tires mounted on factory steel wheels before??? LMAO!
They do try to hang gnarley corners it just ain't happening.
hahaha
yes. if that was you.
i don't care. still faster than stock tires...
i think that's a 390 on an 8" rim lol
Yep... that was me. I actually wound up buying another set at the same time and never even used the ones on steelies. Ya nothing like a 15" wide tire on an 8" rim, PRICELESS! :D
