Need help
sinus19
hey guys... just installed my custom headlights but im i need to connect one last LED inside of them. I want them to turn on when the key is in the ON position (1st click) so what wire can i tap into inside the engine bay to power the LEDS? atleast the positive wire... i can hook the ground to the chassis.
text me later I will tell you which one in the fuse panel is key hot.
I was also going to say fuse box. I'd probably do the radio but I'd test first
You don't have a voltmeter? If not use a light bulb with negative grounded. Probe different wires in the area till you find one that light bulb with key on.
If you haven't found one yet.
Fused ignition switch output (Run)
Pink/yellow
pink/orange, same
pink/white
pink/violet
black/orange
I think all of them connect to relays in the fuse box.
