bump steer kit
ZCx
Well-Known Member
Big D
any one have one they would be willin to part with???
Save your time and money boss. They do nothing! Many unhappy customers that thought this was a cure:(
it did not "cure" the problem , but i did notice a huge difference.
wo
Without the bumpsteer kit on my lowered QC , my front was not safe at cornering combine with bumps in road , it slipped very hard and i need to hold my steeringwheel real tight.
With the kit on , its much more relaxed driving , and yes , i notice still a little bit off bump steer.
If anybody can tell me if there is a "cure" that realy takes all the bumpsteer away and i mean ALL of it , feel free to post !
All the weight on the front with low profile tires does not help this thing corner. Just go strait and you will be fine
Are your bumpstops up front removed? Guys lowered and riding on bumpstops is what I've seen most calling bump steer. It's actually suspension not able to reciprocate up and down.
not removed , i'v put smaller ones in place...
only problem i have with the lowering is that the right side (passenger) is hitting inner fender (plastic) when i go in big dents or at speedbumps...
It seems as if there needs to be something between the two lowering height options. My current truck is stock height and have been wanting to drop it. My last truck I did the 1-2 kit (RC) and had zero complications....although I can't help but like the look of the 2-3 better. My one complaint is that with the 1-2 kit the front only went down 5/8ths of an inch even after it settled in. When clearly the 2 inch blocks lowered the rear an honest two inches I wish the front dropped a full inch. Do you know what the actual drop was on the kit you have?
You can lead a horse to water but cant make them drink. Read that link. Its hard to belive but we do have the same frame and suspension components as the regular ram. Those guys figured out this problem years ago.
i'm not that great mechanic , but i see not that much diffrence with Tony's...:dontknow:
