Stock 2006 front and rear suspension needed
Greg Callahan
Hello,
I am buying a 2006 QC and need to return the suspension back to stock after being lowered to get back the towing capacity to 7,000lbs.
I need every component. Someone must have a box full of this after lowering their own 2006 ram srt-10.
PM me! Thanks!
Hello,
PM me! Thanks!
Can’t you just remove the lower kit in the rear ... and how was the front lowered ?
Check online with X2 builders for the parts
Hello,
PM me! Thanks!
Try Scott @ X2 builders he may have one.
Hello,
PM me! Thanks!
Where you able to get the parts? If not, I have my parts off my 05 QC. I have front springs, rear shackles and u bolts with plates. They should work for your 06.
Rear should work, fronts are different if I recall. I have a set of stock RC front springs which are slighty stiffer and shorter, but they may work
