Thats better hahaha !Okay! Up yours!
Hahahaha!!!
Hahahaha!!!
Yeah, I thought so too lolThats better hahaha !
Did you look up what the word means lolYeah, I thought so too lol
Yes! The owner said he changed it to original oil recently. And also changed the pumpcurious if you got a copy of the CARFAX on it - that could show a paper trail of whatever it's service life was while it was in the system. Hopefully the oil has been changed again since 2020 lol, I use 10/30 in mine.
Did he say why the pump was changed .. that would make me nervous as to why ! Especially with only 50k miles on it . Hopefully it wasn’t run with no oil pressure .Yes! The owner said he changed it to original oil recently. And also changed the pump
Hahaha ! Yes and since the garage queen has such low mileage I’m sure it still has the original factory oil in hahaha.
Nothing better than a woman wanting to stay lubed up!Actually no on Factory stock oil hahahaha - she gets oil and filter change and anti freeze change.
Hahahaha! Gotta keep her lubed and cool![]()
Clever!! You covered all the bases!! Hahahaha!Nothing better than a woman wanting to stay lubed up!
The thing I learned early on is just spend some time tinkering with the front end, until the motor gets warm. Then move on to the under carriage. That REALLY gets the lubricant moving!
If you don’t get the lubricants moving you could end up with a bent pushrod. One other thing, you don’t want is to fiddle with one’s ball-joints while lubing. It will also cause premature failure of the drive shaft.
Nothing better than working on your truck, I always look forward to torquing my nuts
Sounds like a home run win hahahaClever!! You covered all the bases!! Hahahaha!
No no , this was the power steering pump he was on about. Sorry my mistakeDid he say why the pump was changed .. that would make me nervous as to why ! Especially with only 50k miles on it . Hopefully it wasn’t run with no oil pressure .
Ok that isn’t bad then lolNo no , this was the power steering pump he was on about. Sorry my mistake
Outside of leaking OEM lines the hydraulic fan is very good. Lots of people who switch to electric fans find their truck overheating and end up switching back to stock. I don't think JTSVP even sells their electric conversion kit anymore due to the headaches.One of the major design flaws on the truck is the cooling fan. The engineers at Chrysler put on a really jury rigged system. It is in a word TERRIBLE. If it has not yet failed on the truck it is only a matter of time before it will. And when it does there will be power steering fluid blown out coating everything under the hood. The fix is to convert the system to electric fans. A guy in the Carolina's makes a really trick unit that is easy to install and totally eliminates the fluid system. Pricey item. But cures the issue forever.
I'm thinking he got his conversion kit from JMBOutside of leaking OEM lines the hydraulic fan is very good. Lots of people who switch to electric fans find their truck overheating and end up switching back to stock. I don't think JTSVP even sells their electric conversion kit anymore due to the headaches.
I bought mine in the last 6 months. Works perfect. Has 2 fans and is mounted onto a powder coated panel. Came with a complete wiring harness that was a bit time consuming to put in. It got rid of all that whining noise coming from the front of the engine.Outside of leaking OEM lines the hydraulic fan is very good. Lots of people who switch to electric fans find their truck overheating and end up switching back to stock. I don't think JTSVP even sells their electric conversion kit anymore due to the headaches.
That's great mileage!!I bought mine in the last 6 months. Works perfect. Has 2 fans and is mounted onto a powder coated panel. Came with a complete wiring harness that was a bit time consuming to put in. It got rid of all that whining noise coming from the front of the engine.
I live in the Central Valley of California where outside summer temps can go to 115 degrees (were told it is a dry heat). And I have not experienced any issues. Drove it to Famosa Drag Strip in Bakersfield last week for the Hot Rod Garage event, set the cruise at 75 and got 17.3 MPG at a tac speed of about 1400 RPM's. Round trip was 238 miles. I was impressed with the number.
Appears you were moving at speeds most of the time on the trip .. the problem some switched back to the stock system and even oversized and undersized pulleys caused overheating and weak charging system while idling for longer periods and sitting in traffic or long lights especially on hotter days . This has happened to me years ago when modifying for street using certain racing type parts meant for racing .I bought mine in the last 6 months. Works perfect. Has 2 fans and is mounted onto a powder coated panel. Came with a complete wiring harness that was a bit time consuming to put in. It got rid of all that whining noise coming from the front of the engine.
