Well after two years of lowering
So the pic of the gas cap mean they are gas operated bags lol
Nice to see posting TheWelshm… yes I see the fitting installed lol
Yes what improvements did the make in the ride of the truck ?
Amazing difference for less than $400.00, if you have a flip kit installed a must.
Thewelshm
They are an assist to the lowered ride, I can pump 90psi in them if I want to tow, and yes what a difference, it stopped it hitting bump stops on rough roads.
Thewelshm
Cool .. I never was sure what they actually did .. but use to use air shock in the rear a million years ago ..
Thewe
Cool .. I never was sure what the did .. but use to use air shock in the rear a million years ago ..
This kit works with the stock bilstein shocks.
Thewelshm
Thewe
Thewelshm
Mdont have a flip kit , are they still something that would be used ff benefit? For a daily drive ,, I don’t tow wither
Thewelshm
Sweet!
Do you carry a small compressor with you to air up at will?
That setup is great, installed one myself! Since they are such low volume, I considered buying a compact mechanical bicycle pump in case I need to add more to tow/manage extra payload while I'm out.
Actually, here in the future, we can even upgrade to something like these little electronic guys if we're out on the fly and have a little time:
Takes a whole few seconds to fill each side with a full size air compressor. :D
Cool idea putting the valves next to the fuel filler. I was going to mount mine in the hitch, but someone convinced me to put them out in the open in the bumper.
We use to put the air shock lines out the back and connected to a T air stem and stick it through a dole in the license plate .. easy to add ai if needed and couldn’t be noted Fed unless you new what to look for ..
You could easily install a on of switch to a small pump and a pressure gauge.. hidden from site ..even some older cars had the automatic air load levelers ..
I have a train horn set up, that would be easy to do. But for now it works mate.
Thewelshm
That what matters !
There you go .. Horn those things and train them right :D.
