Still having the slightly high idle after installing the X Metal TB. WHat is the proper proecedure for reseting the PCM on the 2006 10's? I read somewhere that it was different on the 2006 models. Thanks guys.
Thanks for chimming in, Ronnie. I haven't touched the idle set screw, as I was told that I really shouldn't and the PCM owuld eventually adjust the idle. But, I'm thinking I should adjust the idle a bit. What are your thoughts on touching the idle screw?rottenronnie said:Remove both battery cables then touch the cables together for 15 seconds or so. Just disconnecting the battery is NOT the same.
If there is something different with the 2006s, someone might be able to let us know, but the above procedure has been working since 1984.
It also works on the new diesels.
PS- Did you turn the idle screw down a bit?
Ronnie
SANTEEN said:Thanks for chimming in, Ronnie. I haven't touched the idle set screw, as I was told that I really shouldn't and the PCM owuld eventually adjust the idle. But, I'm thinking I should adjust the idle a bit. What are your thoughts on touching the idle screw?
You just got me thinkinga little, when you mentioned the 70% throttle. I just hooked up the supechips programmer and the TPS is only showing 78% when pressing the gas all the way down, key on engine off. Could there be a problem with my TPS?rottenronnie said:When my t.p.s. went south and the engine was only seeing 70% throttle, I was swapping e.c.u.s back and forth between stock and the DC stage 2 flash back then-(the days before the SCT) and I didn't really notice much of a power difference with either e.c.u., EVEN WITH THE NEW T.P.S. INSTALLED Hmmmmmmmm?????..... That was because the data from the old defective t.p.s. was being retained in BOTH of the e.c.u.s. The check engine light didn't even trip there was a problem with the data from the t.p.s. 'cause it was still working, at least, I guess, and must have still been within range of the data the e.c.u. would accept.
It wasn't until I rebooted each of the e.c.us. that the power returned to normal levels in each box. The change was immediate.
10 minutes, I haven't tried before but it couldn't hurt....
Ronnie
SANTEEN said:You just got me thinkinga little, when you mentioned the 70% throttle. I just hooked up the supechips programmer and the TPS is only showing 78% when pressing the gas all the way down, key on engine off. Could there be a problem with my TPS?
SANTEEN said:I think that did it. Just went out and back the screw out one turn and now it idles at 750 in drive. Still may be a tad high, but much more tolerable than before. Don't know if I want to come down anymore. What should the idle be in gear and alos in park?
