My ECM did have a canned tune.
It had a lot of blow by. So much it would drip out out of the K&N and run down the inner fender. The intake was also full of oil when it came apart. the motor was definitely ingesting it. The engine also had a different head gasket on the passenger side. I suspect the engine had prior problems with the #10 cylinder.
I was asking 22.5, but I think I have a little room there. Lots of brand new wear item parts come with it. Prolly about 4k in new parts for when they are needed. (Front end suspension stuff, 4 corners brakes & rotors, and some other stuff.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
